If you are looking for a great chip to stack with your tuner but are not sure which one to go with give the BD X-Power a shot. We are so confident the X-Power will be your best choice for stacking we are offering a 30 day trial, no questions asked for the month of July. You will be charged up front for the product. After 30 Days if you do not agree the X-Power is your best stacking option or simply want to try it in place of your current stack combination then don't delay test your X-Power today! ***To much timing can cause a timing rattle that is common when stacking tuners with a performance chip that already has high levels of advanced timing. In this case the regular X-Power (non timing) version is ideal for stacking with a tuner that already advances timing*** The BD X-Power will boost horsepower and torque by controlling Injection Duration only. This works great for those of you who are already using a tuner with high levels of advanced timing and are looking for more power through stacking. This will eliminate the issues associated with running to much timing. The X-Power Plus is also available for a non stacking application with 180HP right out of the box. The BD X-Power Plus will boost horsepower and torque by controlling injection duration and timing. The X-Power Plus is great for those who want all the power with out the guess work involved in stacking a tuner with a performance chip. The X-Power Plus is great to stack with a fuel pressure box but should not be stacked with most tuners using timing advancing. This is not recommended because it may cause issues associated with too much timing which a lot of guys tend to over look when shopping for a stacking combination. The X-Power and X-Power Plus use a fully adjustable dial to fine tune HP anywhere from 0-180 RWHP for optimal power and controlled EGT’s
