Well I have finally started my grease conversion on my '92 CTD I started by gathering parts.. I have filters, fittings, heat exchangers, pollack valve, lava line, and I just started making myself a grease tank.. After looking at a lot of tanks on the web and in person I decided I did not want a tank in the bed of my truck.. (plus I have a bed camper) So I am building my own to go where the spare tire goes on my truck. Here is what I have so far.. I am using 14 gauge steel.. a steel brake I just bought that can bend up to 35" wide. the tank size is 30x30x15 estimate 58 gallons.. you can see in the pick I had to notch a few spots for it to fit where I want it. The biggest question is when it is all done if it will hold with out leaks
Well tank is all welded up so we started on the bottom. we tacked on some c channel that the radiator flid wil lfow threw
THanks I hope to get back on this project very soon.. I am trying to finish up a buddies Toyota build right now.. but this should be back on top of the list soon
