How often does your check engine light come on?
Discussion in 'Dodge 3rd Gen Cummins 5.9 (24v)' started by CK5, Jan 24, 2006.
  1. 4054x4
    my check engine light has come on twice since i got my chip. the code is P0191 which has to do with the fuel rail pressure being too high i think... the dealer said my chip is causing the problem so i took it off. i would rather have a bit less power w/ no check engine light then more power i guess.
  2. CK5
    What chip are you running?
  3. willyswanter
    Bakersfield, CA
    EDGE's and BD's throw that code...
    Steve, I lost track in all the off topic bs, did you ever check your codes?
  4. DWitcher
    DWitcher Well-Known Member
    Bakersfield CA.
    Well that's what you get for trying to keep track. Now back to the subject at hand.:D
  5. the_sandman_454
    the_sandman_454 Well-Known Member
    Saginaw, MI
    So far the check engine light has only illuminated once for a problem (does so every time for the instrument cluster check). The problem was, I forgot to plug the wires back in for the sensor on the air box last time I had it out prior to starting the truck. After shutting it down, it ceased to illuminate.
    Cycle key off to on (but don't start it) 3 times and leave it "on" on the 3rd time, and the odometer should flash the trouble code numbers it has stored. That would be much easier to tell the dealer than simply "light is on", then they can determine it's importance. This works with the 05's at least, owners manual should detail procedure if it turns out to be different. Just another bit of helpful trivia, is if you hold the trip meter reset just after turning the key to the on position it should display engine hours.
  6. Seventy4Blazer
    well i beat mine like a red headed step child and then take it out back and chain it up to beat on it more... and the light has come on 3 times since i have owned it. almost 2 years now.
    over boost 2 times and a bunch of codes that tell me my fuel pedal is going out. ill get it looked at some day. prolly when im on the side of the road. cycle the key 3 times then see what the ODO says.
    Grant
    Grant
  7. CK5
    Forgot about this, here are the codes:
    P0633
    P0514
    P0513
    A search on TDR revealed that quite a few newer trucks are doing the same thing.
  8. willyswanter
    Bakersfield, CA
    Yeah I have had P0514 for ever...
  9. CK5
    Welp, the light went on again so I took it in right away, the Dealer thought it was a problem with the electronics in the key, for those who don't know, 06 has a new style ignition key. They replaced the key, so will find out if that was the problem or not if the light stays off.
  10. SteveinAK
    SteveinAK Active Member
    Mountain Home, Idaho
    Never had the light come on. -Steve
  11. CK5
    Just an update, so far after the key was replaced no light.
