How to get off the TPMS
Discussion in 'Dodge 4th Gen Cummins 6.7 (24v)' started by WhiteWhomper, May 11, 2013.
  1. WhiteWhomper
    WhiteWhomper Member
    Castle Rock, Colorado
    So is there and easy way to get the TPMS from showing a tire pressure issue?
    I have the fronts filled to 60psi and the rears to 70 psi per the sticker on the door, but the code won't reset. I don't like to run that high, but I was trying to get the code to go off.
    Any ideas?
  2. CK5
    You could try backing both down say 10 psi and then driving a few miles to see if/when the light goes out. I would think there has to be a "PSI range" when the sensor is triggered?
