to have just in case, i also hand punched all of this info too......:doah: Moog part numbers for 1st Gen 2wd and 4wd trucks. 93-88 2wd truck numbers: centerlink DS1173 adjusting sleeve ES3124S right outside tierod ES3122R right inside tierod ES3123L left inside tierod ES3123L left outside tierod ES3122R idler arm K7055 upper balljoint K778, K7082(HD) lower balljoint K7025(must replace with K727 if it has 4 wrench flats and is screw in), K7025T(enhanced design), K7053T(HD) upper control arm shaft kit K7036 upper control arm bushing kit K7006(2 required per truck), K7189(1 kit per truck, performance busings), K7104(eccentric bushing kit for more camber) upper control arm bumpstop K7293 lower control arm bushing kit K7077(2 kits per truck), K7193(1 kit per truck, performance bushings) HD lower control arm bushing kit K7065(2 kits per truck), K7192(1 kit per truck, performance bushings) lower control arm bump stop K7282 sway bar to frame bushing K7096 sway bar link repair kit K7081 rear leaf spring bushing 1" O.D. x 1/2" I.D. SB266 rear leaf spring bushing 1 1/2 O.D. x 3/4" I.D. SB268 93-88 4wd truck numbers: upper ball joint K8194T lower ball joint K8195T bump stop K7282 lower kingpin K992(provides 1 1/2 degree of camber adjustment) lower kingpin bearing kit K8832 upper kingpin bearing kit K6652 sway bar to frame bushing with 1 1/16 bar K7302 both sizes are thermoplastic bushings sway bar to frame bushing with 1 3/16 bar K6172 swaybar link repair kit K7081 right tierod ES2010R left tierod ES2010L draglink DS914 adjuster tube DS1411S front leaf spring bushing front and rear SB266 FEL-PRO engine gaskets and seals head gasket 9332PT head set w/o gasket HSU9332 gasket conversion set CS9332 (includes oil pan gasket)\ exhaust manifold gasket set MS92089 exhaust pipe gasket 60928 oil pan gasket OS34102 rear main seal and gasket set BS40633 valve cover gasket set VS50396R pushrod cover gasket set PS50397R valve stem seal SS70819-1 water outlet o-ring 35526 water pump gasket 35525 timing cover gasket TCS45902 anchor industries motor mounts 2wd front motor mount 2710 tranny mount N/A 4wd front motor mount 2710 trans upper mount 2667 trans lower mount 2668 Carlson Brake Part Numbers D250 w/ 12x2.5 drum front disc hardware kit H5516 pad shim kit 18063 caliper repair kit 41099 bleeder screw H9402 caliper piston 7535 for phenolic, 7501 for steel caliper support spring H5315 inner bushing H5209 rear drum hardware kit H7199 brake drum pro kit H2316 guide pin H4087 bolt sleeve H547 adjustment screw spring H430 self adjuster repair kits H2598 left, H2599 right wheel cylinder repair kit 45004 hold down pin H1119 hold down spring H1164 adjuster lever H2049 left, H2048 right cable guide/pivot H2093 cable H2104 lever return spring H2140 left, H2141 right adjuster screw assembly H1534 left, H1535 right D350 w/ 12x2.5 drum front disc hardware kit H5516 pad shim kit 18063 caliper repair kit 41099 bleeder screw H9402 caliper piston 7535 for phenolic, 7501 for steel caliper support spring H5315 inner bushing H5209 rear drum hardware kit H7199 brake drum pro kit H2316 guide pin H4087 bolt sleeve H547 adjustment screw spring H430 self adjuster repair kits H2598 left, H2599 right wheel cylinder repair kit 45004 for 7/8" wc bore, 45002 for 1" wc bore hold down pin H1119 hold down spring H1164 adjuster lever H2049 left, H2048 right cable guide/pivot H2093 cable H2104 lever return spring H2140 left, H2141 right adjuster screw assembly H1534 left, H1535 right D350 w/ 12x3 drum front disc hardware kit H5516 pad shim kit 18063 caliper repair kit 41099 bleeder screw H9402 caliper piston 7535 for phenolic, 7501 for steel caliper support spring H5315 inner bushing H5209 rear drum hardware kit H7199 brake drum pro kit H2316 guide pin H4087 bolt sleeve H547 adjustment screw spring H430 self adjuster repair kits H2598 left, H2599 right wheel cylinder repair kit 45002 for 1" wc bore, 45019 for 1 1/16" wc bore hold down pin H1119 hold down spring H1164 adjuster lever H2049 left, H2048 right cable guide/pivot H2093 cable H2104 lever return spring H2140 left, H2141 right adjuster screw assembly H1534 left, H1535 right Four Seasons Temperature Control Products system specs R-12, refrigerant capacity 44 oz., oil capacity 4.6 oz for 93, 7.25 oz for 92-89 blower motor w/ A/C 35474 blower motor w/o A/C 35560 93-92 SDB709 type compresor w/ clutch S57562 91-89 C171 type compressor w/ clutch 57106 non-intercooled condenser 53298 intercooled condenser N/A evaporator core 54108 expension valve/orifice tube 38849 intercooled fan clutch 36936 non-intercooled fan clutch 36705 filter drier/accumulator 33555 heater core w/ A/C 94619 heater core w/o A/C 94600 93-90 tensioner assembly 45844 89 idler pulley 45981 clutch cycling switch R-12 35800 clutch cycling switch R-134a 36677 coolant temp sensor 36425 low pressure cut out 35752 water outlet 85181 tranny coolers: Ultra-Cool light duty 53000 medium duty 53001 heavy duty 53002 Rapid-Cool light duty 53005 medium duty 53006 heavy duty 53007 Modine Radiators, Condensors, Heater Cores specifications core size 25 3/4 x 21 x 2 1/4 (3row) inlet header 2 5/8 x 21 1/4 outlet header 2 5/8 x 21 1/4 inlet connection 1 3/4 left outlet connection 2 right pin mount 93-92 radiator 2460 93 condenser 300034 92-90 condenser 300031 89 condenser 300025 heater core 702463, 702464 heater core specifications 702463: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is beside core 702464: 8 x 6 1/2 x 2, inlet/outlet 5/8, in/out is above core
Delphi/Lucas POD Injectors Cummins Part #3802335 Recon#3802335RX Delphi Part# 6760524 Specs For the POD Injectors: Supplier # LJC6760524 Cummins Nozzle # 3919316 Supplier Nozzle # 6801127 Nozzle Opening Pressure (Bar) 260 6 Cylinder CPL # 940 Tip Diameter = 7 PDC Kit 3802335 These injectors were used for Engine CPL 940 which is classified as turbocharged yard trucks. Throttle Bellcrank Bushings These are the replacement bushings for the throttle bellcrank. If your bellcrank has alot of play, these will fix the problem. Dodge Part# 4425053 Retail for $1.95 each. You will need two. VE Gasket/Seal Kit Part # DGK121 (Bosch) expect to pay around 15-20 bucks. Vacumn/Power Steering Pump Oil Seal Kit Cummins Part # 4089842 Upgraded Cummins Piston Transfer Pump Kit to replace diapraghm pump (piston type is used on P7100 systems, however, psi is lower to accomadate the VE pump Cummins Part # 3936320 lift pump (qty 1) # 3914753 Fuel Line (qty 1) # 3931348 Gasket (qty 2) # 3914284 Spacer (qty1) # 3918191 Seals (qty 2) Lift pump block off plate This is installed where the mechanical lift pump would go if you were upgrading to an electronic pump and needed to block the mechanical lift pump hole. Cummins Part # 3863441 Getrag Rear Seal For 2wd (all year models) Chicago Rawhide Part # 19762 Throttle Linkage Rod & Ends Cummins part# 4089076. This includes the rod, the 2 nuts, 2 steel ends and the new ball that the one snaps on. Price was $21.82. Fuel Shutoff Solenoid 028-130-135-B 36.00 from Valley Wagon Carson City NV Phone Number 775-882-2350 Oil Psi Sender Cummins Part# 3923200 VE Pump Breakover Spring 1-464-651-430 3200 RPM Gov Spring most places......also called the 366 spring Belt Tensioner Cummins Part# 3935819 Spicer U-Joints 5-160X Updated Thermostat for 89-93 models Cummins Part# 3802968 Speedometer Sensor Napa Part# VSS100 Updated Flex Plate This is the part number for a 95 model. This is a direct bolt on for the 1st gens and should be used in place of the old part number for added durability especially on modified trucks. Chrysler Part # 5015709 Price $295.00 Cummins Part #3946161 Price $ 94.22 Carter Electronic Lift Pump (replaces stock unit) block off plate for old pump is needed. plate for a 350 Chevrolet engine can be used. http://store.summitracing.com/partde...=CRT%2DP4600HP Intake Heater Relay (Discontinued thru Dodge but available thru Grainger and Misc other electrical suppliers) White-Rogers Relay Part #120-105111-1 with a coil of 12V DC cont. 9370. Stancor Relay Part #120-901 http://www.kubicki.tv/GridHtrSolenoids.pdf http://www.stancor.com/pdfs/pg91_92.pdf Upgraded OEM Fan and Fan Clutch Dodge has issued an updated Fan which has more twist on the blades and is lighter. If you plan on upgrading your fan clutch, I strongly suggest you also upgrade to this new fan. Again, this is an OEM component from MOPAR. Fan #52026653 Clutch module #52028760
This part number is exactly what I'm looking for. Thanks a bunch! and you did a great job in providing us this list of Parts and Part Numbers. waytogo
