what oil do you use?
Discussion in 'Ford Powerstroke 6.0' started by H-Power, Apr 8, 2007.
what oil do you use and why?
  1. Motorcraft
    9.0%
  2. Shell Rotella T
    44.9%
  3. Chevron Delo 400
    10.1%
  4. Royal Purple
    1.1%
  5. AMS oil
    15.7%
  6. Pennzoil
    1.1%
  7. Other
    18.0%
  1. hendo
    hendo Active Member
    ok all of you like your oil , but what experience do you have and can tell about the stuff you dont like
  2. Diesel Nut
    I have been and Amsoil user for 7 years now, and a dealer for almost 3. As a customer, I have had mid to high hp trucks that have never had a wear related issue. One of my best friends dad got me on Amsoil after witnessing his chevy half ton with nearly 300k on the 350 crank up right away every monrning. Since then I have used it in everything i have including my lawnmower.
    Since then, I have done much research and testing. I have blown many people away with the torch test on Amsoil's ATF. Very interesting little test.
    Bottom line is use what you like. Synthetics aren't for everyone, some people just don't understand synthetic oils and people tend to fear what they don't understand.
    As for benefits, expect less wear, slightly better mileage, smoother idle and cooler temps in transmissions and axles. Expect to go farther between oil changes and spend less time working on your regular maintenance. Also, expect it to cost LESS than regular servicing with conventional oil.
    Jason
  3. SubYuman
    SubYuman Member
    CJ-4 Rotella T 5-40
    I still can't find it here in the Mojave desert, even at truck stops. ANy idea when it'll be out?
  4. toterhome
    toterhome New Member
    what oil?
    The Shell Rotella is easy to get at Sams club in a 55 gallon can.
  5. Duluth Diesel
    AMSOIL of course. I've run it for over a decade in everything I own.
    -Chuck
  6. dodgerep
    dodgerep Well-Known Member
    Texas
    Premium Blue goes 25K between changes
    I use Valvoline premium blue and have very satisfying results from it. Would not change at this point.
  7. powershooter
    powershooter Well-Known Member
    Goochland County, Va.
    was using shell rotella but 5,000 miles ago i switched to amsoil 15w-40 syn and am pleased so far . the rotella would darken after 5,000 but the amsoil is still very light brown , very clean looking with the help of the by-pass filter . :) it cost more to get going with the by-pass filtration and oil but i will save money in the long run .
  8. PRCA Bullfighter
    PRCA Bullfighter Member
    Molina, CO
    I run Amsoil 15w40 in both of our trucks and am getting ready to put Amsoil in all four of our differentials. I'm getting great oil analysis reports using the 15w40 as well. I used to run the series 3000 and didn't get as good of results but I'm very pleased with the 15w40.
    Justin
  9. fubar
    fubar Member
    Been running Rotella 15-40 in the spring / summer and Rotella 5-40 fall / winter. Always change around 4500- 5000 and always run Fram or M/C filter. Thats about it 4 1/2 years and almost 250,000 on it. [04 6.0 Lariat c/cab.]
  10. H-Power
    H-Power Well-Known Member
    Honoulu, HI
    hey diesel nut, I'm planning on switching to amsoil on my next oil change coming up soon with 5w-40 premium diesel oil API CJ-4. later on I'll change my trans and rear end with amsoil
  11. Diesel Nut
    Right on. On your 06 you should stick with the 15W40. The 5W40 is designed for the new motors, and you don't need to run that in your older motor. The 15W40 is a CI-4 oil instead of a CJ-4 and will work better for your 6.0L.
    Also, I doubt it ever gets cool enough in HI to think about needing a thinner oil.rotfl
  12. H-Power
    Honoulu, HI
    thanks for advice diesel nut
    yea i know high 60s what was i thinking :doah:
  13. CainIV
    CainIV New Member
    Jacksonville, NC
    How much dose it help?
    Iv been thinking about puting in an oil-by pass on my truck. How much dose it help?
