Who has the best manual tranny?
Discussion in 'Brand Wars' started by CK5, Mar 11, 2005.
  1. WSTEPHENS
    WSTEPHENS Well-Known Member
    Douglassville, PA
    The G56 is a good transmission in spite of the lower OD ratio IMHO. TDR had one with 80K miles on it taken to a major transmission rebuiler to be tore down and looked at and then compared to the NV5600. When the transmission was taken apart they found several heavy duty features found in Eaton or Spicer Medium Duty Truck transmissions that were not found in the NV5600
    The G56 has been used in MB Medium Duty trucks for quite awhile before Dodge started using it in the HD 2500 and 3500 trucks.
    The early problem found with the G56 was they were first shipped to the dealers with out enough oil in the them and they were burning up and stopping procduction. Once that was corrected they put them back into production.
    I have had a ZF5 in the 90 F250 before and I like the G56 better and inspite of the lower geared OD I am still able to get over 20 mpg when crusing on the high way better than I got with the 99 2500 Dodge with the automatic and 3:54 which got good mileage.
  2. rocknbronco
    rocknbronco Well-Known Member
    Flat Top Mtn,Tn
    I say NV5600:D
  3. LOUDandPROUD
    Kodiak, Ak
    How about them ol' 4 speeds. Look how many of those are still on the road in original form....I had one and it would pull anything, maybe not fast but it would pull!
    waytogo
  4. Rob Knoell
    Rob Knoell Well-Known Member
    nm
    Okay, so it sound like we have just three major choices for for six speeds. We have the Ford ZF series, the NV5600 and the new Dodge G56. I don't think that the Ford tranny is bad, if fact quite the oppisite. Ford does seem to have a great tranny it is just the 6.0 that is the problem for these trucks. The NV5600 was an awesome tranny. No doubt about it. I currently have the G56 in my 1 ton dually, crew cab, 4x4. My only gripe with the tranny is that even with the 3.73 gears in the pumpkins I wish I had a seventh gear. I have hauled 25,000 pounds with the truck and did not need a lower gear. But, when I get out on the highway I wish I had another gear for cruising. At 65 mph the engine is running at 2000 rpm's. Perhaps this is not too bad for either the Ford or the Chevy due to their higher reving engines. But the Cummins redlines at 3200 rpm's. For me the fuel mileage drops dramaticaly if I run the engine past the 2000 rpm's. I have yet to see a need for a 4.10 ratio in my truck.
  5. rocknbronco
    Flat Top Mtn,Tn
    Yeah but with the six speeds you can have your cake and eat it to:stir: .
  6. Diesel-Dude
    Diesel-Dude Well-Known Member
    north central, Ohio
    Another vote for the NV-5600. The one in my truck started to shift kinda hard back last fall when the weather was getting cold. Simply changed the trans oil with the high quality, full-synthetic oil of my choice (make sure you get the right stuff as the 5600 is awful picky about the correct oil) and it now shifts as smooth as any other truck tranny out there.waytogo
  7. CoastalDav
    CoastalDav Well-Known Member
    Melbourne, Florida
    What oil did you use??
    Dave
  8. Diesel-Dude
    north central, Ohio
    Amsoil Synthetic Manual Syncromesh Transmission Fluid. http://www.amsoil.com/StoreFront/mtf.aspx
    First time I've ever used an Amsoil product and I can honestly report a definite shift-quality increase over the factory fill.
  9. gone camping
    gone camping Well-Known Member
    So far I like my six banger with the six speed manual and six wheels. Pulled my 5er up and over Cheat Mtn West Virginia like it was nothing. The route has a 9% grade with 15, 20 , and 30 MPH curves. I cant wait to do it again.waytogo
  10. tosch88
    tosch88 Active Member
    The one thing that is nice about the G-56 is its aluminium case. It runs about 20 degrees cooler than the NV 5600. These tranny's are all made and designed by the same supplier, Magna, which bought out New Venture Gear. I used to do business with NVG\Magna. We manufactured gears for them.
  11. 96psdiesel
    96psdiesel Member
    NV5600 is the best, why dodge ever got away from that is beyond me. Their new manual is a piece of junk, the gears are way to close together. The ford 6-spd is a close second, and gm pulls in 3rd place. The best i personally owned was a 00 F-250 T444E with a 6-spd 3.73.
  12. WSTEPHENS
    Douglassville, PA
    Dodge got a way from the NV5600 because it is not longer made so Dodge had to go somewhere else to find a replacement. I have put over 45K on my G56 and it has been a very good tranmission.
  13. rocknbronco
    Flat Top Mtn,Tn
    Now a days it's Dodge/Ram or nothing....
